I've ran into an issue with a stair assembly that has two as its quantity number. This shows up in the model browser, the detail and detail list. However when I open the main parts properties the assembly quantity is only 1 and there is no numbering issue(such as two assemblies with the same part mark.) No matter what it seems to add an addition assembly. When I change the assembly quantity to 4 it will reflect 5 in the model browser and my drawing upon update. Any ideas what's going on? thanks julian
I worked around this by coping the entire assembly with a base point, deleting it and reinserting it into the model. Then I manually assigned my assembly part mark. This worked fine because I hadn't started cleaning up the drawing but wouldn't have been ideal if I already had. Unfortunately I don't have a dwg saved that is still in this condition to figure out what was going on. Thank you though
