Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
main part quantity issue
2 REPLIES 2
279 Views, 2 Replies
I've ran into an issue with a stair assembly that has two as its quantity number.  This shows up in the model browser, the detail and detail list.  However when I open the main parts properties the assembly quantity is only 1 and there is no numbering issue(such as two assemblies with the same part mark.)  No matter what it seems to add an addition assembly.  When I change the assembly quantity to 4 it will reflect 5 in the model browser and my drawing upon update.  Any ideas what's going on?  thanks julian
2 REPLIES 2
wtheron
Hello Julian,
Can you upload a sample model.dwg ?
in reply to: wtheron
I worked around this by coping the entire assembly with a base point, deleting it and reinserting it into the model.  Then I manually assigned my assembly part mark.  This worked fine because I hadn't started cleaning up the drawing but wouldn't have been ideal if I already had.  Unfortunately I don't have a dwg saved that is still in this condition to figure out what was going on.  Thank you though
