Indian Rolled Steel Section in Structural Elements
vaibhav_parkaleU8KDT
Dear Team,
Please support on below ensue.
I need to create  Ladder, handrail in advance steel with using Structural Elements. Actually i want to use Indian Rolled Section for all those elements.
Please suggest how to add Indian rolled section in Structural Elements.
Please find Image for more clarity.
Tomislav.Golubovic
If you click on the first triangle on the left of the Section Name, you can pick a different profile
@Tomislav.Golubovic Thank You for response,
Actually, option below shown in image (All) Is not showing. Please refer below image. Please suggest.
crydee-AG2
Some joints only allow the use of certain sections in certain places. The cage ladder being an example. These are controlled by a database table.
Use Management tools and Table Editor. Open Installed Databsases then find AstorRules > JointsGUIAllowedSections. In this table you have five columns.
  • Key = Next available number.
  • JointName = the name of the joint to control - look for it already in the table somewhere. Cage Ladder = CageLadder
  • JointControl = the Setting in the joint to control - look for an existing entry in the table. Ladder Stringer = Stringer
  • AllowedSectionType = All sections of a certain shape or of a certain class. I would stick with Section Class.
  • AllowedSection = The TypeNameText of the desired section class as found in the AstorProfiles > ProfileMasterTable table. Look for your known name in the RunName column then copy what is in the TypeNameText column. e.g.
Indian Rolled Steel Channels (IS:808) = INDIAN IS Channel
If you search the various help sources (Autodesk, Graitec blogs, this forum). You might find specific answers for specific joints.
After any changes update Defaults and then you should be good to go. Remember that these settings only exist on your PC so others will not be able to edit your joint.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
