Dear Team,
Please support on below ensue.
I need to create Ladder, handrail in advance steel with using Structural Elements. Actually i want to use Indian Rolled Section for all those elements.
Please suggest how to add Indian rolled section in Structural Elements.
Please find Image for more clarity.
@Tomislav.Golubovic Thank You for response,
Actually, option below shown in image (All) Is not showing. Please refer below image. Please suggest.
Some joints only allow the use of certain sections in certain places. The cage ladder being an example. These are controlled by a database table.
Use Management tools and Table Editor. Open Installed Databsases then find AstorRules > JointsGUIAllowedSections. In this table you have five columns.
Indian Rolled Steel Channels (IS:808) = INDIAN IS Channel
If you search the various help sources (Autodesk, Graitec blogs, this forum). You might find specific answers for specific joints.
After any changes update Defaults and then you should be good to go. Remember that these settings only exist on your PC so others will not be able to edit your joint.
Aleck Giles, Structures Consultant, Graitec
