Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
IFC import issues
1 REPLY 1
tonilipovac
443 Views, 1 Reply
IFC import issues
I cant imfort ifc file (IFC 2x3).
In attachment you can find ifc file.
Could you please try to import.
Thank you in advance.
1 REPLY 1
AleckGiles
in reply to: tonilipovac
Advance Steel can basically only import properly defined IFCBeam and IFCColumn type objects that are proper solids. No Breps or other object types. If you open that IFC file in a viewer you can see that there are no IFCBeam or IFCColumn type objects and the only object types are "Proxy" objects that are all Breps with no other meaningful properties. Therefore there is nothing intelligent in that file for AS to import.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
