Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to turn on presentation of folds in folded plate Mainpart.
2 REPLIES 2
prakhar.kanungo
128 Views, 2 Replies
Hi all,
I work on AS 2022. The problem I faced was in USA environment.
I have a 12 face polygonal folded plate column. I want its folds to be shown in drawings too. Right now in the front or side it is showing only plane face like its a normal circular plate.  I want the folds to appear in erection drawings, assembly and single part drawings. Please see the attached images depicting the way I want folded plates to be presented and the way I am getting them right now.
This the way I want folded plates to be presented
This is the way I am getting them now.
What changes Do I need to make in the settings to achieve the desired output.
2 REPLIES 2
you can switch of folded lines in GA drawings:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thanks a lot
Technology Administrators
