Hi all,
I work on AS 2022. The problem I faced was in USA environment.
I have a 12 face polygonal folded plate column. I want its folds to be shown in drawings too. Right now in the front or side it is showing only plane face like its a normal circular plate. I want the folds to appear in erection drawings, assembly and single part drawings. Please see the attached images depicting the way I want folded plates to be presented and the way I am getting them right now.
This the way I want folded plates to be presented
This is the way I am getting them now.
What changes Do I need to make in the settings to achieve the desired output.
Solved by Sebastian_Eiche. Go to Solution.
you can switch of folded lines in GA drawings:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
