Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
how can i shorten additional elements without trimming or deleting?
3 REPLIES 3
414 Views, 3 Replies
when i regenerate a model into a drawing, i use "assembly and additional element" from model objest selection tab. I need the additional elements for top view but not for cut view so is there a way i can shorten the additional elements without trimming or removing them entirely?
*Attached is just a sample drawing with markings on what i need and what i need shortened.
Your reply will be highly appreciated.
3 REPLIES 3
HarryHighpants
I am not 100% sure this will work, but for the plan view I would use a camera box. That would give you control over the extents.
For the other views, you can generate them using single part drawing styles.
Hope that helps.
alickomay
would clip not do the job ? (double click green box of drawing look for clip)
in reply to: alickomay
Thank you so much 🙂
