Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
part numbering
2 REPLIES 2
292 Views, 2 Replies
part numbering
i thought i had this figured out in 2015 but now in 2016 i cant seem to get the same results im wanting.
i'm trying to get the main assembly mark for a beam to look like this.   (1B1)  where the 1 represents the current sheet, B is the prefix and the last 1 is the counter.
so sheet 2 would be (2B1).
the single parts i got to look like i wanted with the prefix and then the counter number.
all i can get right now for the main mark is (B1).
I've tried every combination i could think of.  any thoughts?
2 REPLIES 2
Jonathan.Jasinski
You will need to generate the drawings then update your numbering to get the sheet number to show up in the number itself.
in reply to: Jonathan.Jasinski
Thanks Jonathon,
but it actually turned out to be something else.
since i was testing the system and trying different settings to get what i wanted, the system database somehow got "gummed" up.  I copied the model to a fresh sheet and then tried the settings i used before and everything worked fine.
