HOLES MISSING ON DETAIL DRAWING OF A PLATE
rahulmhaskar20
rahulmhaskar20
Hello People,
I am trying to create a drawing of a plate. It has a hole created automatically by an anchor as in the image below.HOLE.PNG
but when i try to make a drawing of this plate, I do not get the hole in drawing.
Can anybody solve this problem?
Thanks.
Rahul.
múinteoir
It maybe the case that the drawing style is set not to show holes from anchors. What drawing was used to create the plate drawing? You can check this by double clicking the outer green frame.
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
rahulmhaskar20
The anchor holes in drawing style are on.
I can frame this problem correctly after a few observations.
This anchor i am using is a custom one. The holes are seen in drawing if a standard library anchor is used. But if i insert custom anchor in model, i do not get a hole on plate in detail drawings.
suicidedoors
If you go into your management tools and select use filter, type in hole. Drawing Presentation will be one of the options on the list, expand that and then select General, check "Holes in erection drawings"
