Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
grid on plan view
5 REPLIES 5
1055 Views, 5 Replies
grid on plan view
How to customize grid to appear on Plan View?
Tags (1)
5 REPLIES 5
lk
If grid is not visivle in the view you have to edit "object presentation" for user view styl:
Leszek K
in reply to: lk
Thanks for the fast reply. I mean the grid lines that are on the level other then base plate level are not showing up. I have 4 levels of beam plan views and I want the grid lines appear on each of the plan view.
lk
Ithink you have to copy grid on each level
Leszek K
abs30116
in reply to: lk
Leszek is correct. You have to copy the grid lines up to each level for them to appear. I put them on the Hidden Grid layer so I can turn them off and make it easier to work in the model.
jpnoronha
Hi
In 2023 version there is a new option:  Grid Projection\Project Grid Vertically for Model Views and Drawings.
Hope it helps
Technology Administrators
