How to customize grid to appear on Plan View?
Solved by abs30116. Go to Solution.
Thanks for the fast reply. I mean the grid lines that are on the level other then base plate level are not showing up. I have 4 levels of beam plan views and I want the grid lines appear on each of the plan view.
Hi
In 2023 version there is a new option: Grid Projection\Project Grid Vertically for Model Views and Drawings.
Hope it helps
