I need to add a notch or a cut out section on the grating in my project, how do I do this?
Thank you for your time and help!
Solved by Jonathan.Jasinski. Go to Solution.
Solved by múinteoir. Go to Solution.
Rectangular Contour 2 Points, UCS will work well for this
I am a newbie with Advance Steel, where do I find the button for that fly out menu?
Thanks!
Thank you for your help. I did find it after clicking on ALL the buttons in every category until I found it. Talk about learning on the fly 😕
Thanks for the answer. What's the difference between "green" and "orange" on the Features tab?
Thanks again
Gennaro
Green can be done on either plates (gratings) or beams. Blue can only be preformed on beams. Orange can only be preformed on plates(gratings)
