Removing 'Feature' (Cut) Lines
will5L99Z
will5L99Z
Hi All,
I am currently altering a model for a Staircase which has lots of cuts, however i have changed my profile representation from Feature to Standard, and the cut lines are still there?
Apologies if this has been answered before, i have searched!
Sebastian_Eiche
look like the feature are not placed by a profile..these are plates. So if you change the plate to standard, the feature should be not shown.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
will5L99Z
Thanks Sebastian, all my sections are shown as 'Standard'
Is there a way to select all parts and only change display type?
Sebastian_Eiche
in the Advance Toolpalette, there's a categorie for filter...now filter plates and then right mouse button click Advance Steel Properties...presentation style "standard".
You could also use the button "standard" in the tool palette categorie "Quick views"
Sebastian Eiche
will5L99Z
Thanks so much, always helping!
RonBuckingham
I would select one cut feature, right click and pick "select similar". This should select all of the cut features, then go to Quick Views and pick "selected objects off".  Would that do what you need?
Ron
