so not sure how you created the drawing views from the model, if you created them manually via a style and selected a viewport, then those positions are stored in the view created. If I recall under the drawing itself and the properties you can see this and I seem to recall there is an option to move the main drawing plane from its origin , but you have to check.
you may find you can move where the view is created.
if you used a camera object and a drawing process, then just move the camera and the view will show an update required I expect but it will be the same size, style etc. ( cannot guarantee that you will not have to redo any manual work to that view)
if you change is just a level change of the whole model, then you could leave the model at the same vertical model co-ordinates and use the AS level symbol and settings to override the global level displayed.
anyway just some idea’s thought etc.
HTH
John Bennett
