I have generated all the drawings for a site prior to having all the final site elevations figured out. Is there a way to shift the drawing viewpoints with the model shifts? For example, if the drawings were all generated at 100.000 and now the whole model needs to shift to 100.500, the drawings, when updated, will all be screwed.
so not sure how you created the drawing views from the model, if you created them manually via a style and selected a viewport, then those positions are stored in the view created. If I recall under the drawing itself and the properties you can see this and I seem to recall there is an option to move the main drawing plane from its origin , but you have to check.
you may find you can move where the view is created.
if you used a camera object and a drawing process, then just move the camera and the view will show an update required I expect but it will be the same size, style etc. ( cannot guarantee that you will not have to redo any manual work to that view)
if you change is just a level change of the whole model, then you could leave the model at the same vertical model co-ordinates and use the AS level symbol and settings to override the global level displayed.
anyway just some idea’s thought etc.
HTH
John Bennett
HTH
John Bennett
