As the title states, is it possible to include the project number token in a drawing list?
I tried but the drawing list is not showing up whenever the token is present.
You need a the project number in the list on drawing?
Why don't you include this number in the pageheader? Maybe you create some pics, what you want
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
We will be implementing a barcode in our drawing with the project number and phase information. We could implement it with block attributes but to minimize the error we wanted it to be automated, thus the drawing list. However, as mentioned, the Project number won't show up.
The barcode above is only for the Phase token.
the combination of two words into one barcode is not easy and You will need to add "*" the token, otherwise the barcode could not be read (QR Codes are easier)
The Projectnumber is not readable in the bom list, so I would use the Hypersteallpage header, therefore you will not need to do something manual.
The projectnumebr is given in the püorjectsettings in the model and will be shown automatic in the hypersteelpageheader if you adjust it correct:
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-00036924-E652-4D4A-B121-B0CE96859CE5
Sebastian Eiche
Hi Sebastian,
As far as I understand it HYPERSTEELPAGEHEADER is used in prototypes, right? Is Phase token can be used as well?
