I am trying to add a 3d view to the DSM. The help files are showing a "Tie Beam" on their list, well I don't have "Tie Beam" on my list. I am stuck, please help.
Joseph
Solved by FCort. Go to Solution.
We need more information. What do you want to add? A view to an existing detailstyle like mainpart?
There's no existing automatic iso view, therefore you will need to add a view based on ucs.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
I've only ever added 3D views by creating a separate camera or creating a separate drawing then adding (moving) it to my drawing sheet. This isn't Solidworks, Inventor, Fusion 360 or any other kind of GOOD 3D software where you can simply add views at the click of a button. Advance Steel is a horrible kludge of a software package.
After looking into this further I see I am missing a download "tie beam" . The link that is provided does not work. I am still on this but can use help.
Thank you
I'm personally not aware of any drawing style that will let you create a 3D view of any particular object alongside the 2D views. That said there are also other drawing styles that are locked away in some of the different region builds. For example "Cladding GA" is in the UK build but not US, so you can't create a general arrangement view of cladding (with labels and a table) without going through a bunch of work and effort to figure it out. I guess that according to AutoDesk and Graitec cladding doesn't exist in North America so we don't get pre-loaded drawing styles to use it!
Any of the 3D views seem to be based on the UCS, and I'm unaware of how one creates a view from the individual object CS (Coordinate system) within any given drawing.
So.... here is what I do:
Congrats! In only 15 convoluted steps you've now placed a 3D view in your drawing! Pat yourself on the back and try not to think about how you're paying thousands of dollars annually on this for this software that never improves.
This, to my knowledge so far, is the only good way to do it. You can use the 'create 3D views from selected objects' drawing style without using a camera BUT if your object ever has new parts added to it those won't update, so its a really limited option.
In other software like Solidworks, Inventor, Fusion360 etc you can do all this in a few clicks with more control, options, and general enjoyment of your existence.
the problem is "based on UCS".
The steps are not needed if you could use the same UCS for all mainparts (I know this is not working in the most cases but for some users it is)
By using the same UCS, you culd create an additional view in your MP-Detailstyle which is based on UCS and modelobject is the Mainpart.
If you then run a process for MP the there will be a 3D view for each MP based on this UCS.
Sebastian Eiche
See the attachment. I think this is what you are asking
Something to add that may be helpful in creating isometric views:
Holes won't show up by default, and it isn't controlled by the drawing style. Instead that setting exists in Management Tools, which overrides the individual drawing style settings that are typically used to create the camera/iso/detail views.
This page in the built-in AS Help explains how to add a 3D view to an assembly drawing style. You can use this method on any style for any model object. It does not have to be a tie beam or anything else. Just find the right style for the object you are drawing and edit that. You can find the style used in a drawing by Double Clicking the outer green frame around the view and looking in the bottom left of the Detail Properties dialog.
When you produce the drawings you will need your UCS set for a 3D view and the same 3D orientation will be used for all drawings made in that process.
Aleck Giles, Structures Consultant, Graitec
