A few questions
Is "Model Role" just another filter?
Why use "groups" when we have "lot/phase"?
Attributes are used for what?
Are Groups and queries just 2 ways to do the same thing?
Using these functions seem to be easy, I am not seeing the difference between them.
JK
Solved by AleckGiles. Go to Solution.
Solved by Dias_Antonio. Go to Solution.
==> Model Role is a (parameter/atribute/characteristic/property) you input in your element member
==> Groups are elements with properties in comon
==> Some projects need properties that are not native ou default in Advance Steel, for example: in progress / in manufacturing...
==> Query is a way to search some element in your Model Space. You make a query to seache "22 mm bolts"
==> Yes they are easy to use. Just search and know their functions
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
Model Roles tell Advance Steel what a given part or assembly is so it can select the correct drawing rules (Drawing Styles) to use when drawing the object. IF you select poor model roles you will get poor drawings. NOTHING makes a bigger difference to the drawing than using the correct Model Roles. It is critical to getting the best drawings.
Aleck Giles, Structures Consultant, Graitec
