Dear Expert,
My own drawing BOM Template inserted in drawing & updated. After that the drawing detail is exploded.
The drawing BOM Template location & size are disturbed in exploded drawing. What issue? How to rectify? https://autode.sk/3qAZ1Xp
When inserting your list you ticked all four corners thus trying to lock the deposition of al four corners. This would prevent the list from growing to show the required lines of data. This was ignored and the list changed size. I think this is the cause of your problem. I have never seen a list with all four corners locked.
if you place the list at the top of the sheet it should be able to grow downwards so you lock only the top two corners. this fixes the width and scale of the list but allows the length to grow to add as many lines as required. The list will not move when updating now. It will stay in the corner where you put it. This is how the lists are done on all the UK prototypes and we have never seen a list move or change scale when exploding a drawing.
Please try that.
Aleck Giles, Structures Consultant, Graitec
Dear Expert,
Thanks for your detailed reply. Please see the below link.
In my Template was one point in orgin. Now, my issue is cleared.
