Dear Expert,
How to off hatch pattern for cut views in drawing style for that which one is selected in object presentation?
could you create a screenshot or something?
Your question is not clear for me
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Dear Expert,
Try lines, 11,12,15, they have cut in the presentation definition.
cut normally indicates under the style that the hatch pattern to the cut/section face.
also here there is a line for the curved beams as well.
John Bennett
You create changes in the Advance Area of the detail style manager...Be carefull with that, this is area is normally blocked for changes.
Only the user area should be changed, to have backup the Advance Area "should untouched"
Sebastian Eiche
Dear Expert,
Dear Expert,
In section (cut) views no hatch required.
How to set that drawing style manager?
