I did some changes in my model, when I force update my GA drawing and it just disappeared. Literally gone from my folder on my server. I have the back up files but not my current drawing that I have have been working on for months.
Is there to fix the link / connection from drawing to model if I use the back up drawing file? I want the changes that I do in the model to be reflected in the GA drawing.
I don't want to start over and recreate a drawing that has months worth of work put into it at this point.
Thanks!
Solved by iwafb. Go to Solution.
Yes there is, you can re-register the drawing back to the model.
Copy/restore the dwg file back to the details folder, then use the "register documents to model" tool...
Save the model when drawing is registered...!
