Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Straight beam by start point - end point: operation failed, not a straight beam (using Dynamo)
12 REPLIES 12
Message 1 of 13
brisid.isufi
605 Views, 12 Replies
From time to time, I receive this warning (image below) in Dynamo. The two points are clearly distinct, and there is no way to have a curved line anyway, since I am simply supplying two distinct points in space. What is strange is that the warning disappears when I close and reopen Advance Steel or when I make changes to the coordinates of the nodes.  Any idea what is causing this issue?
In order to prevent bothering the community further in the near future, the bigger question is: where can I find detailed documentation for Dynamo nodes for Advance Steel? This is all I found: https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU... , and the Github repository, and I find it hard to navigate since it provides only minimal information for each node.
12 REPLIES 12
Message 2 of 13
Dynamo Primer is the best documentation - see Github. It is available in several languages ​​and as a pdf for download.
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 3 of 13
brisid.isufi
in reply to: brisid.isufi
Thank you for your answer, but Dynamo Primer has no information about Advance Steel nodes (if I am not mistaken). I am having difficulties and lack of information related to Advance Steel nodes, not Dynamo in general. As an opensource effort I understand that the community itself is responsible for the documentation, but I am checking just in case there are some resources already existing out there.
Message 4 of 13
it starts on page no. 77 in Primer ... look in Dynamo (plugin for Advance Steel) for possible nodes
Message 5 of 13
brisid.isufi
I am afraid I am using the incorrect version of the Dynamo primer. The one I found on Github is this one: https://primer.dynamobim.org/en/Appendix/DynamoPrimer-Print1_3.pdf
Is this the one you are referring to? Page 77 in the aforementioned document has content unrelated to Advance Steel. Thanks!
Message 6 of 13
https://blogs.autodesk.com/bimblog/category/dynamo/#
Message 7 of 13
https://primer2.dynamobim.org/
Message 8 of 13
and the best one with full nodes description: https://dictionary.dynamobim.com/#/
Message 9 of 13
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=AdvanceSteel_Dynamo_Dynamo_for_Advance_Steel_Dy...
Message 10 of 13
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=AdvanceSteel_Dynamo_Dynamo_for_Advance_Steel_Cr...
Message 11 of 13
This is basically the same link I posted in my original post. So in short, the answer seems to be that there is not much more than this link available specifically for Advance Steel.
Message 12 of 13
Unfortunately, not all nodes are well described, for some you have to look in Dynamo for the requirements for each input information
Message 13 of 13
Nodes for Advance Steel 2023:
https://help.autodesk.com/view/ADSTPR/2023/ENU/?guid=AdvanceSteel_Dynamo_Dynamo_for_Advance_Steel_Dy...
