all of a sudden with no reason the width of our connection vault pallet has changed. I cannot find a setting or a default to get it back as it was. In the pic, you see the other pallets are not changed??
Solved by wtheron. Go to Solution.
@wtheron wrote:
Expand the palette, then hide the part of the palette with the descriptive graphics and instructions for each joint. Bottom right hand corner there will be a series of dots you can use to resize the palette.
What do you do if there is no apparent way to expand the pallet ?
If your problem persists, you can delete from registry the folder with the name of the ToolPalette causing that error.
For example, if Connection vault is not displaying correctly, in Advance Steel 2016, delete the following:
HKEY_CURRENT_USER\Software\Autodesk\AdvanceSteel\2016\Settings\Dialogs\AdvPalette\connectionvaultdata
Make a backup of the registry before this operation!
Bogdan.
