Columns wont appear in camera detail.
gage_guerin8JBPJ
gage_guerin8JBPJ
Trying to implement a new system at work, where we cut drawings from models via the cameras(using 0-3d models w/ labels as the drawing style for the camera.) In the DSM, i was able to change the object representation of beams to show up as widgets (shown in figure 1). This is perfect for what I need besides the fact that there should be a beam face/column showing in each of the corners of this plan view. I have also attached the styles in the DSM i am using.
(figure 1)
DMorton_Graitec_Mtl
Make a copy of the Beams rule. Move it above the original Beams line and set the rule for objects seen from Side/width and the presentation to visible.
gage_guerin8JBPJ
Thank you for the explanation and the step by step picture! One more question I have is, is there any way to show a gap at the end of a beam line when it comes into contact with a main beam (that way one could tell what beam is the main one that everything is connected to). TIA
DMorton_Graitec_Mtl
On Full size shape representation it reads the geometry from the model, where the beam ends, that's where the 2D will display.
On Symbol or Single line representation, you can use the gap option. This will pull back the end of the system/single  line in the 2D drawing from where it was originally drawn. This does not read the face or web of a column, only where the system lines end points are located in the 3D model.
gage_guerin8JBPJ
Thank you! Usually i like to play around with the settings and figure things out for myself but I didnt have time for that this time. Much appreciated
DMorton_Graitec_Mtl
You are not really able to leave a gap from an object. You can add a gap distance when using line or symbol but this only shortens the line displayed by x amount and does not recognize the other objects.  For example, if you shorten the line by 1/2", when the beam is going to a column web this might be good but it would still be shortened by 1/2" when going to the column flange. The line is pulled back from the column center in both cases but not far enough in the second circumstance.
