CHS Drawing is Not shown properly
Mitch_Burchett
Mitch_Burchett
Hi all.  I am trying to produce and NC1 file, of a CHS, complete with end cuts and holes mid length.  All I can manage is a mitred end as the only option to change the CHS profile.  Is there a DSTV setting(s) to produce a true 3D CHS NC1 file, complete with cuts, holes etc.?  I am using AS 2019 and would be grateful for any advise.  Cheers, Mitch.
johnjmbennett
Try this, this changes the nc from saw to flat pattern:
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU...
Also to get nc1 you just need to adjust the file extension under management tools defaults .
https://forums.autodesk.com/t5/advance-steel-forum/advanced-steel-nc-format/td-p/7345165
John Bennett
Mitch_Burchett
Hi John. Thanks for that, however it was that FAQ that lead me here. The example depicts a 3D pipe with holes, a mitre and a cut. I have replicated the scenerio but cannot get the same 3D depiction. Our client wants to see an NC1 file containing a 3D CHS as a pipe with features, not unwrapped (which works nicely BTW). AS seems too complex not to be able to do this, so I feel I may have missed a setting somewhere to turn on/off show features (maybe)?
johnjmbennett
Not sure that NC1 file is designed to do that, it is just a text format.
Suggest an sat file. This is via a bolt on.
https://m.youtube.com/watch?v=OiX06PrNGbY
Also seen export via ifc to nc processing software.
John Bennett
Mitch_Burchett
Thanks John.
