Display Issues
Display Issues
Display Issues
Hi All,
I am having an issue with the slope washers on the windbracing showing as being about 2'-0 or in size. The issues I have is it is supposed to be about 2-3"
Any suggestions?
I change it from 1/2 rod and it will sometimes go away, sometimes I have to change the size again to get it to fix itself.
I am having an issue when I insert another building into the master model, the inserted building only shows the grid. I edit the block and it will show up, sometimes. Any suggestions?
I found if I do an audit, and purge it fixes it.
