I'm trying to change the bolt grade of A325 from grade 10.9 to ASTM A325.
I had tried changing the 10.9 under material column in AS management tools/Table editor/AstorBase/SetBolts. But this do not work.
Your help is much appreciated.
Joseph
Joseph
Solved by Emanuel.Nestor. Go to Solution.
A related question, I have created new bolts with the new ASTM F3125 designation with a grade of A325.
Everything works fine except when I review the joint design of the connections the bolts always fail with 0 kips. Is there a step I missed in the data base for this?
