Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Change grade of A325 bolts from 10.9 to ASTM A325
21 REPLIES 21
Message 1 of 22
joseph_hermogenes_042016
6380 Views, 21 Replies
I'm trying to change the bolt grade of A325 from grade 10.9 to ASTM A325.
I had tried changing the 10.9 under material column in AS management tools/Table editor/AstorBase/SetBolts. But this do not work.
Your help is much appreciated.
Joseph
Joseph
21 REPLIES 21
Message 21 of 22
in reply to: Emanuel.Nestor
A related question, I have created new bolts with the new ASTM F3125 designation with a grade of A325.
Everything works fine except when I review the joint design of the connections the bolts always fail with 0 kips. Is there a step I missed in the data base for this?
Message 22 of 22
Have you inputted the bolt property as per message 19?
Regards,Joseph
Regards,Joseph
