can't change the size of the holes
eyal.ch
eyal.ch
Hi All,
I have a problem changing the size of the holes so in the drawing it will appear correctly.
In the parameters of the connection, I changed the size of the bolts to 12 and the tolerance for the hole to 3mm
and it supposes to be 15mm in the hole.
when I clicked the bolts I get:
I can't change the size of the hole in the parameter of the bolts, it's in grey.
in the drawing I get this:
please help
sdonohoedesign
In the makro, you have the variable hole tolerance set only for the plate.
Set it to plate & beam
eyal.ch
Hi @sdonohoedesign,
Please be more specific, I don't know how to reach the Macro,
can you please elaborate so I can change it?
I'm stuck!
thank you.
Flies_Eyes
I've had headaches with this macro in the past as well.  I can't recall now if I resolved by doing an Update all in the Macro or edited the holes separate to the macro.
eyal.ch
Hi All,
I have to jump this post again,
I have a very big problem with this matter, can anyone suggest how can I edit the holes that are in grey?
the hole tolerance suppose to be 3mm, how can I change it?
when I click the hole feature I get this, 13mm instead of 15mm:
I don't know what to do.
mick-CNF
Hi @eyal.ch
You have set the hole tolerance for 3mm in the plate and the labelled drawing is the beam.
You will have to select both or the beam.
In your last image the hole in the plate is set bigger.
eyalch_0-1657290111009.pngeyalch_1-1657382516771.pngScreenshot 2022-07-11 085726.png
If this information solves your problem please accept as a solution.
vuongbui.nuce
thanks this is helpful
