When we send our plates to sheets, it puts the plate name in the BOM using the Name token. However, the name token for plate shows the thickness, width and length.
Is there anyway to remove the length from the description?
Solved by Emanuel.Nestor. Go to Solution.
You can change the name of the plates using Management Tools application.
Follow this steps:
Please find attached a picture with the option from MT.
Please let me now if this is what you are looking for.
Best regards,
Emy
