Good morning,
I'm trying to get the projects data (project, client, costumer,etc.) in the attributes menu so as to add them in my customized stamp, how can I get them?
as well as the approval status and drawing name. I already know how to get autocad attibutes, but I can't find the AS's ones.
Thanks regards.
Solved by múinteoir. Go to Solution.
Please see below list of attribute available in Advance Steel
Token | Description |
PROJECT | Project Name |
PROJECT_NO | Project No. |
CLIENT | Client Name |
BUILDING | Building Name |
BUILDING_LOCATION | Location of the Building |
CONTRACTOR | Contractor Name |
DATE_ORDER | Date of Order |
DATE_CONSTR | Date of construction |
DESIGNER | Checked by |
DETAILER | Detailed by |
MODEL_DWG | Name of model.dwg |
DRAWING_NO | Drawing number |
POS_NUM | Piece mark of the object |
DATE_DRAW | Date of created drawing |
SCALE | Scale used for detail |
MATERIAL | Material of the object |
REVISION_INDEX | Revision index |
REVISION_AUTHOR | Revision created by |
REVISION_DATE | Revision date |
REV_COMMENT | Revision description |
COATING | Coating of the object |
PHASE | Phase / Lot of the object |
FILENAME | The name of the DWG file |
ROLE | Model Role |
NAME | Description of the part |
OBJECTTYPE | Object Type |
QUANTITY | Quantity of the part required |
USERATTR1 – USERATTR10 | User Attributes 1-10 |
USERPROJATTR1 | Project user attribute 1 |
USERPROJATTR2 | Project user attribute 2 |
USERPROJATTR3 | Project user attribute 3 |
USERPROJATTR4 | Project user attribute 4 |
USERPROJATTR5 | Project user attribute 5 |
APPROVAL_STATUS | Drawing Approval Status |
APPROVAL_DATE | Drawing Approval Date |
APPROVAL_COMMENT | Drawing Approval Comment |
Jonathan Hand
Software Application Engineer
Graitec UK
