Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance steel attibutes definition
2 REPLIES 2
antonio.delacruz
704 Views, 2 Replies
 Good morning,
I'm trying to get the projects data (project, client, costumer,etc.) in the attributes menu so as to add them in my customized stamp, how can I get them?
as well as the approval status and drawing name. I already know how to get autocad attibutes, but I can't find the AS's ones.
Thanks regards.
2 REPLIES 2
Please see below list of attribute available in Advance Steel
Token
Description
PROJECT
Project Name
PROJECT_NO
Project No.
CLIENT
Client Name
BUILDING
Building Name
BUILDING_LOCATION
Location of the Building
CONTRACTOR
Contractor Name
DATE_ORDER
Date of Order
DATE_CONSTR
Date of construction
DESIGNER
Checked by
DETAILER
Detailed by
MODEL_DWG
Name of model.dwg
DRAWING_NO
Drawing number
POS_NUM
Piece mark of the object
DATE_DRAW
Date of created drawing
SCALE
Scale used for detail
MATERIAL
Material of the object
REVISION_INDEX
Revision index
REVISION_AUTHOR
Revision created by
REVISION_DATE
Revision date
REV_COMMENT
Revision description
COATING
Coating of the object
PHASE
Phase / Lot of the object
FILENAME
The name of the DWG file
ROLE
Model Role
NAME
Description of the part
OBJECTTYPE
Object Type
QUANTITY
Quantity of the part required
USERATTR1 – USERATTR10
User Attributes 1-10
USERPROJATTR1
Project user attribute 1
USERPROJATTR2
Project user attribute 2
USERPROJATTR3
Project user attribute 3
USERPROJATTR4
Project user attribute 4
USERPROJATTR5
Project user attribute 5
APPROVAL_STATUS
Drawing Approval Status
APPROVAL_DATE
Drawing Approval Date
APPROVAL_COMMENT
Drawing Approval Comment
Jonathan Hand
Software Application Engineer
Graitec UK
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Thanks a lot Jonathan, very useful info.
Regards.
Antonio.
