Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
continuous footing Profiles
2 REPLIES 2
443 Views, 2 Replies
I’m adding some continues footings into my model. However I only found 1 Rectangular Profile. Profile is under: Standard Profile – Rectangular – R1’6”x3’
Where do I add more profiles to the “Standard Profile – Rectangular” category? Maybe a R14'0"x5', Please Advise.
2 REPLIES 2
Emanuel.Nestor
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi peter,
The "concrete" sections are not saved in a database.
You modify the section dimensions directly in the section name field.
Use "Click" in the right side of the section name (not over the section name) and then the field become editable.
Please find attached picture showing you how it looks.
Here you can modify the dimensions as desired.
This behavior is common for all concrete sections (and steel sections 🙂 ).
I hope this can help you.
Best regards,
Emy
Emy Nestor
Hi peter,
Best regards,
Emy
Emy Nestor
in reply to: Emanuel.Nestor
It works perfectly, Thank you!!!!
