Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
BEAMS Not Aligned in Join creation
5 REPLIES 5
531 Views, 5 Replies
As you can see in the photo. Im trying to make 2 diferent joints, with different IPE dimensions. The problem comes when I realize that when i make the joints, the "heigth" of the beams are not the same ( Obviously because the Dimensions of the beams are different ) . How can I modified the join to line up the two beams ( green in  the photo ) .
Much thanks  and best regards
5 REPLIES 5
CHRIS_ASDL
Have the beams been modeled within the frame macro?
Kind Regards
Chris
Drawtech
Looks like you maybe have the system lines of the beams aligned, but both are on centre of beams? (it's difficult to see in the shaded view)
...so you need to set system lines to top centre position on each beam (and make sure they are aligned).
It is not an issue with the joint, but in the position of the beams themselves.
Dave Gronow
Drawtech Services Ltd
in reply to: CHRIS_ASDL
Yes, I use the Macros to make my Joints . Is this incorrect ?
CHRIS_ASDL
Yes this is correct. What I did mean was if you had modeled the beams with the framing macro or manually detailed these?
Kind Regards
Chris
CHRIS_ASDL
I've uploaded a screen cast.
Hope this helps.
Kind Regards
Chris
Technology Administrators
