After several successful days in AS 2024, I suddenly cannot open the BOM Editor. After creating the list, I get the following message:
Has anyone had a similar problem? Many thanks in advance
Solved by cristian.udreaBYPDW. Go to Solution.
Try the following knowledge article - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/mscorlib-error-mes...
Rob Merriman, AEC Technical Lead, Graitec
Hi @Rob_Merriman,
my problem does not fall into the listed categories ... returning to the factory settings did not help, the only thing left is a new installation ... yet, many thanks
Hi all,
I only get this error message if I work outside of our company network (e.g. HomeOffice with internet connection) and try to open the BOM Editor
If I try to generate BOM via palette, the next error will be occured:
From your error message it looks like your Windows Registry is missing required entries for a COM class that is part of Advance Steel.
Does your work outside of your company network mean moving to a different PC, or using the same PC on a different network ?
many thanks for your feedback. It's the same PC on a different network. Can the problem be supported by the fact that I still have version 2022 parallel to 2024 installed (due to database migration)? Because one colleague also has both installations and the same problem, and colleagues only have no problems with 2024.
Hi @bigcarl5000kg , @Karel_Grygar_EQOS
Please try to copy the following dlls:
From C:\Program Files\Autodesk\AutoCAD 2024 to the C:\Program Files\Autodesk\AutoCAD 2024\ADVS folder.
Please let me know if this works for you.
WOW 👍
Your solution works perfect, and saved an incredible amount of stress and extra work.
If only all the mistakes in the world were so easily solved... 😁
MANY THANKS AND HAVE A NICE DAY
