Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel 2024 - can't open BOM Editor
9 REPLIES 9
Message 1 of 10
Karel_Grygar_EQOS
393 Views, 9 Replies
After several successful days in AS 2024, I suddenly cannot open the BOM Editor. After creating the list, I get the following message:
Has anyone had a similar problem? Many thanks in advance
Transmission tower is a passion
https://eqos-energie.com/en/overhead-line-construction/engineering/
9 REPLIES 9
Message 2 of 10
Hi @Karel_Grygar_EQOS
Try the following knowledge article - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/mscorlib-error-mes...
Rob Merriman, AEC Technical Lead, Graitec
Message 3 of 10
Hi @Rob_Merriman,
my problem does not fall into the listed categories ... returning to the factory settings did not help, the only thing left is a new installation ... yet, many thanks
Message 4 of 10
Before doing a fresh install try deleting the ASSettings_User.xml file located in C:\ProgramData\Autodesk\Advance Steel [version]\[LANG]\
Jonathan Norton
Blog | Linkedin
Message 5 of 10
Hi all,
I only get this error message if I work outside of our company network (e.g. HomeOffice with internet connection) and try to open the BOM Editor
If I try to generate BOM via palette, the next error will be occured:
Message 6 of 10
Hi @Karel_Grygar_EQOS,
From your error message it looks like your Windows Registry is missing required entries for a COM class that is part of Advance Steel.
Does your work outside of your company network mean moving to a different PC, or using the same PC on a different network ?
  • If it's a different PC, you can try reinstalling Advance Steel 2024 to fix this issue.
  • If it's the same PC, please ask your company IT specialist about any Active Directory or other settings that might affect your registry based on login.
Message 7 of 10
Hi @cristian.udreaBYPDW,
many thanks for your feedback. It's the same PC on a different network. Can the problem be supported by the fact that I still have version 2022 parallel to 2024 installed (due to database migration)? Because one colleague also has both installations and the same problem, and colleagues only have no problems with 2024.
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 8 of 10
I get that message if I have not saved the model first.
Message 9 of 10
Hi @bigcarl5000kg , @Karel_Grygar_EQOS
Please try to copy the following dlls:
  • Xalan.Aec.dll
  • XalanMessages.Aec.dll
  • xerces-ad-c_3.dll
From C:\Program Files\Autodesk\AutoCAD 2024 to the C:\Program Files\Autodesk\AutoCAD 2024\ADVS folder.
Please let me know if this works for you.
Message 10 of 10
WOW 👍
Your solution works perfect,  and saved an incredible amount of stress and extra work.
If only all the mistakes in the world were so easily solved... 😁
MANY THANKS AND HAVE A NICE DAY
Technology Administrators
