I'm trying to create 5x5mm grooves around a thick walled CHS but cannot figure out the process, any ideas anybody?
Stephen.
Solved by mick-CNF. Go to Solution.
Solved by Rob_Merriman. Go to Solution.
Good morning,
Could you send through a 2D Sketch of what you want to achieve so we can point you in the right direction
Rob Merriman, AEC Technical Lead, Graitec
Combination of rectangular contour and polar array.
Many thanks for the response guys. Another colleague used the polygon contour at UCS which worked perfect. The array is also another option.
Have a good weekend.
Stephen
