Adding grooves to a CHS
SHDetailDesign
SHDetailDesign
 I'm trying to create 5x5mm grooves around a thick walled CHS but cannot figure out the process, any ideas anybody?
Stephen.
Rob_Merriman
Good morning,
Could you send through a 2D Sketch of what you want to achieve so we can point you in the right direction
Rob Merriman, AEC Technical Lead, Graitec
mick-CNF
Combination of rectangular contour and polar array.
If this information solves your problem please accept as a solution.
SHDetailDesign
Many thanks for the response guys. Another colleague used the polygon contour at UCS which worked perfect. The array is also another option.
Have a good weekend.
Stephen
