Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Select attachments from Autodesk Docs in forms.
If you want to add an attachment to a question in forms, you currently only have the option to browse in your own system. It would be desirable to also be able to browse in the folder structure of Autodesk Docs itself.
3 Comments
dimitris.vernon
Hi Wim - this is available, but you need to use "references" (instead of "attachments"). References would then let you choose from the files you have access to
wim_de_winter
References is available for the total form but not for each question.
dimitris.vernon
and you specified as much in your original post...apologies I misread!
