Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Build should provide a utility to create a list of markups automatically. I love the markup feature, but when reviewing large drawing sets, it is very helpful to provide a list of all the markups as feedback to our A/E's for use a a checklist. Adobe has this feature built in, but the PDF engine of Build does not add markups as a native PDF "comment". I grew tired of this lack of functionality so yesterday I used Grok AI to create a python script to do it for me.
NOTE: this program uses the fact that Build seems to use a particular font (Arial Unicode MS) for it's markups. If the original drawings contained this font anywhere the output would be a mess. For this reason my program is not optimal.
If a total non programmer like me can do it than a billion dollar company like autodesk can do it!
Here is the code: written in Python for windows 11, it can be compiled into a standalone executable.
import fitz # PyMuPDF
import csv
import tkinter as tk
from tkinter import filedialog, ttk
def process_text(doc, font_name, progress):
results = []
for page_num, page in enumerate(doc):
# Update progress
progress['value'] = (page_num + 1) / len(doc) * 100
progress_var.set(f"Processing page {page_num + 1} of {len(doc)}")
root.update_idletasks() # Update the GUI
text_dict = page.get_text("dict")
for block in text_dict["blocks"]:
if "lines" in block:
block_text = []
for line in block["lines"]:
line_text = []
for span in line["spans"]:
if font_name in span["font"]:
line_text.append(span["text"])
if line_text: # Only add if we found matching text in this line
block_text.append(''.join(line_text))
if block_text: # Only add this block to results if it contains matching text
results.append((' '.join(block_text), page_num + 1))
return results
# Create the main window for the progress indicator
root = tk.Tk()
root.title("PDF Text Extraction Progress")
root.geometry("300x150")
# Progress Bar
progress = ttk.Progressbar(root, orient="horizontal", length=200, mode="determinate")
progress.pack(pady=20)
# Label for progress text
progress_var = tk.StringVar()
progress_label = tk.Label(root, textvariable=progress_var)
progress_var.set("Starting...")
progress_label.pack()
# Open file dialog for input PDF
input_file = filedialog.askopenfilename(
title="Select PDF File",
filetypes=[("PDF files", "*.pdf")]
if not input_file:
print("No file selected. Exiting.")
root.destroy()
exit()
# Open file dialog for output CSV
output_file = filedialog.asksaveasfilename(
title="Save CSV File",
defaultextension=".csv",
filetypes=[("CSV files", "*.csv")]
if not output_file:
print("No output file selected. Exiting.")
root.destroy()
exit()
doc = fitz.open(input_file)
matches = process_text(doc, "ArialUnicodeMS", progress)
# Write results to CSV
with open(output_file, 'w', newline='', encoding='utf-8') as csvfile:
csvwriter = csv.writer(csvfile)
# Write header
csvwriter.writerow(['Text', 'Page Number'])
# Write data
for text, page in matches:
csvwriter.writerow([text, page])
# Update progress to 100% when done
progress['value'] = 100
progress_var.set("Finished!")
# Wait for user to close the window
root.protocol("WM_DELETE_WINDOW", root.quit)
root.mainloop()
print(f"CSV file '{output_file}' has been created with the results.")
