License manager not working for pre 2024 products
gbiallas
Message 1 of 27
gbiallas
A machine with Revit versions 2021 through 2026 installed will open versions 2024 and later but not 2023 and earlier. I had to update the ODIS folder to get rid of the "License Manager is not working" error to get anything to work. Short of reinstalling everything, any suggestions on how I can get my older versions working?
Replies (26)
Message 2 of 27
ivo.lafeber
same problem here, we don't have the solution yet.
Message 3 of 27
ivo.lafeber
Make sure you have the autodesk licensing version 15.7.1.13908 running and make the C:\ProgramData\Autodesk full control for the Users.
Message 4 of 27
gbiallas
The licensing version certainly looks like the problem. Anyone know where I can download an installer for it? When I go to the Autodesk Support site it keeps pointing me to the latest version.
Message 5 of 27
bjlottis
It stopped working for me after the latest update (16.0.0.14411) through Autodesk Access. I haven't figured out how to undo this back to the previous version.
Message 6 of 27
ivo.lafeber
I wanted to upload the file in this reply, but that doesn't work.
Message 7 of 27
bjlottis
Autodesk Support helped me out. They confirmed the issue is with the latest version. They uninstalled 16.0 and reinstalled 15.7.
Message 8 of 27
tgoodwinX2SUJ
Same issue.
Message 9 of 27
tgoodwinX2SUJ
5 figure software subscription and your options for support are a broken chatbot or a 3rd party... anyways, reverting to 15.7 fixed the issue
Message 10 of 27
brett_cci
I dealt with the same problem with AutoCAD Electrical 2023 following updating the licensing service to 16.0 yesterday early afternoon. A day later, I'm finally back up and running after re-imaging my hard drive from a backup made prior to the update. Autodesk was of zero help! I'd likely still be wasting time running license troubleshooters and uninstalling/reinstalling license programs per Autodesk's troubleshooting guide had it not been for this forum. Thank you for posting it!
I do see that the license service update has been rolled back to version 15.7 on my product updates list.
Message 11 of 27
BIMdalorian
How? were you able to revert?
Message 12 of 27
BIMdalorian
Message 13 of 27
ivo.lafeber
C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing   there is a program uninstall.exe you can run that once or twice to uninstall the curent version.
you can download the installer from this we-transfer link, It will be active for a couple of days.  https://we.tl/t-tuK6k3GnYD
Message 14 of 27
brett_cci
https://manage.autodesk.com/products/updates is now showing autodesk licensing service version 16.0.2.12 instead of 15.7 that was back earlier today. I'm assuming 16.0.2.12 fixed the issue with 16.0.0.14411? Should only need to install the newer version to replace the faulty 16.0 version without having uninstall first.
Message 15 of 27
ivo.lafeber
I saw that update too, I asked the autodesk support if this update was the solution for the licensing error, this was the answer :
Please do not apply this update as this will cause loss of access to versions 2023 and earlier.  Our engineering team is aware of this issue and is mow working to resolve this matter.  The next update that will be released in the next few days will address this issue.
But for now please do not update to this licensing service and keep using the 15.7 version that we installed.
Message 16 of 27
brett_cci
Good to know. Thank you for checking!
Message 17 of 27
Simon_Weel
Was hit by the same error. Look for 'Current' under "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing". This is a Junction. It points to one of the installed license services. To roll back to the previous version, open a CMD as Admin and perform these commands:
ren "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current" current.old
mklink /J "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current" "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\15.7.1.13908"
The first command renames the existing Junction, just in case.
The second command creates a new junction to the previous license service.
Reboot and you should be good to go.
Message 18 of 27
deepti_bhardwaj
Hello @gbiallas
Here is the structured approach to fix the licensing error that you are getting:
1. Update Autodesk Licensing Components
2. Use Autodesk Licensing Support Tool
  • Autodesk provides a tool to reset or repair licensing for 2020–2024 products.
  • Download and run the tool from this article:\ Autodesk License Support Tool. Licensing and Sign-in Helper
3. Reset Licensing Manually (Advanced)
4. Check Network & Firewall
5. Clean Uninstall if Issues Persist
Message 19 of 27
brett_cci
I’m assuming your step-by-step guide is intended for situations where installation issues stem from factors outside of Autodesk’s control. In this case, however, my understanding is that this particular problem was caused by Autodesk pushing out a faulty Licensing Services update, which resulted in a catastrophic system failure. And yes, being forced to shut down and restart an Autodesk product every ten minutes absolutely qualifies as a catastrophic failure.
I personally completed every step outlined here except for a full uninstall/reinstall of all Autodesk software (thankfully I found this forum prior to proceeding with it):
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Licensing-Error.ht.... None of these steps resolved the issue.
So, where are the instructions for when the licensing failure is caused by Autodesk? If Autodesk can’t be bothered to properly test updates before release, then at the very least there should be an option within the licensing troubleshooter to easily roll back the Licensing Service to a previously working version.
Because of this update failure, I, and by extension my company, lost an entire day of productivity. We pay a considerable amount for Autodesk products and services, and we expect a higher level of reliability and quality control than what we experienced here.
What’s truly disappointing is that, other than reading word-of-mouth reports from other users in this forum, I have not personally received anything from Autodesk acknowledging their role in this issue or offering any form of apology. And @deepti_bhardwaj (assuming you are with Autodesk based on your username), even your response here did not acknowledge Autodesk’s involvement. Instead, you posted troubleshooting steps that, in my view, imply the problem lies on the user’s end.
I’m certainly not without my faults, but when I make a mistake, I take ownership of it, starting with an apology and, more importantly, immediately doing whatever is necessary to correct it.
Message 20 of 27
deepti_bhardwaj
Hello @brett_cci
Thank you for sharing your concerns.
Autodesk is aware of this licensing issue and has acknowledged it publicly. They have released an official article addressing the problem and providing guidance:
"Requested service not available..." launching or using Autodesk software
This article confirms that the issue was caused by a recent Licensing Services update and outlines the steps Autodesk recommends to mitigate the problem. The guidance includes instructions for repairing the licensing components and restoring functionality.
Current Status:
  • Autodesk has identified the root cause and is actively working on a permanent fix.
  • The issue primarily impacts Autodesk 2023 products, though some users on other versions may also experience disruptions.
  • If the problem persists after applying the recommended steps, Autodesk suggests upgrading to 2025 or 2026, as these versions include updated licensing components that resolve the issue.
  • A rollback option for the Licensing Service is not currently available through the troubleshooter, but Autodesk has acknowledged the need for better recovery options in future updates.
I completely understand the frustration this has caused, especially given the impact on productivity. Your feedback about testing and rollback options is valid and aligns with what many users have raised. We are reviewing these concerns internally. And we appreciate your patience with us!
