Chromium host executable" running in your Windows Task Manager. These are helper applications for Autodesk products, taking care of web communication - they are based on the web ( HTML ) component "Chromium" (the same root as Google Chrome)
Check these out https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Multiple-instances-of-ac...
https://forums.autodesk.com/t5/installation-licensing/3dsmax-2017-acwebbrowser-exe/td-p/7014271
https://forums.autodesk.com/t5/maya-forum/what-is-acwebbrowser-exe-and-how-do-i-disable-it/td-p/6285... not sure if this one applies because it's for autodesk maya
Hope this helps ITK
You can close all running AutoDesk software, end task of all running background Autodesk componants, find ACWebBrowser.exe on your system and rename the file to ACWebBrowser.exe-temp
It cannot run what it cannot find.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
