how to make realistic ground texture from real image like this
samroutc
Message 1 of 9
samroutc
hey im new for 3ds max and i want to make realistic texture for ground how to make displacement map and bump map
like this http://tutorials.cgrecord.net/2015/11/how-to-setup-real-displacement-textures.html
Replies (8)
Message 2 of 9
Francisco_Penaloza
The Same principle, as you do in Cinema 4D it can be done in 3 D Max or any 3D Software.
Go to the mere website that sells those images and you can see information regarding 3D Max.
Message 3 of 9
samroutc
I meant how to make maps from the photo i post to make realistic image like in the video
Message 4 of 9
samroutc
Did he make the maps from single image ?
Message 5 of 9
samroutc
It look so realistic
Message 6 of 9
Francisco_Penaloza
it is a more complex process than just a photo.
His products are actually photo scanning of the ground, so he gets actual depth data and can generate a geometry out of the scanning.
Not only one photo but several pictures, later on with different software you can create/extract high map, diffuse maps, normals and others.
https://en.wikipedia.org/wiki/Photogrammetry
You can also read about Autodesk recap and similars.
Message 7 of 9
samroutc
Is there free software photogrammetry ?
Message 8 of 9
Francisco_Penaloza
Most of them are paid or pay per month, i is a good deal if you have a small budget.
http://3dscanexpert.com/autodesk-remake-review/
http://www.agisoft.com/
Message 9 of 9
darawork
I've had some good results with this: https://www.allegorithmic.com/products/bitmap2material
But, you can essentially make the separate elements yourself in photoshop.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
