3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
uv multi sub mapping bitmap?
1 REPLY 1
311 Views, 1 Reply
hi!
i'm having some issues with the uvi multi sub object mapping , mainly for some reason i cannot use bitmap textures. i created some textures on gimp and exported them as jpegs but for some reason i am unable to use them in uv sub mapping
any ideas why and how to use jpeg images on uv multi sub mapping?
please reply as soon as possible, i really need to be able to do this
many thanks,
shelley
1 REPLY 1
You should not have any proplem useing jpeg as material maps:
Try this:
1) draw a simple box
2) assign a multi sub object material
3) select material number 1 (ID 1) and assign std material
3) under maps or diffuse - assign a bitmap and then select the material map (jpeg) to the diffuse channel.
assign this to the box and it should show up as a sub-material.
