Too much reflection
Too much reflection
ottothenerd
Too much reflection
ottothenerd
Greetings fellow 3dsmaxians
I have only recently joined your covenant and truth be told I am a complete noob.
That aside, I've made an object, I'm using arnold, there's 2 lights in my scene, left and right, quad arnold lights.
When the object rotates, the material I've assigned for the screen area shows too much reflection, how do i turn that all the way down?
Thank you
CiroCardoso3v
There are a couple of things you can do. First, I would tackle the roughness of the material. If you need some information regarding PBR workflow, let me know and I can share it with you.
The second way, which is something you should only do in the last instance is removing the specular contribution from the light in question.  Set Specular to 0
But first, check the material and add some roughness to it.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
ottothenerd
Shooting the roughness of the material to 1.0 did the trick, thank you so much.
Sure if its no trouble pls provide me with more info as per the 'PBR Workflow', I know very little of max and it's very exciting
CiroCardoso3v
You are welcome.
You can start with these two guides
https://substance3d.adobe.com/tutorials/courses/the-pbr-guide-part-1
https://substance3d.adobe.com/tutorials/courses/the-pbr-guide-part-2
Ciro Cardoso
