3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Rendering problem with material unshown
2 REPLIES 2
290 Views, 2 Replies
I'm new to 3ds max, I'm having the problem while rendering.
The material of the flooring didn't show up, I don't know what to do and why...
it does show in the viewport
2 REPLIES 2
rendermaster
try to lower light intensity. seems the scene is way to bright
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Francisco_Penaloza
Check that the material is loading your texture.  Also, did  you place any UVW Map on that geometry?
It is a solid object or a single plane, maybe your normal is pointing in the wrong direction.
Also adjust your exposure, as right now as mentioned by @rendermaster the image is way too bright.
As a rule of thumb never use 100 White materials or 100 black. stay within85% it should be fine.
