- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I'm working on a 360 degree video as a final project in my 3D animation class. I can't install Vray so I instead opted for mental ray and using the wraparound camera lens. It works pretty well but my only problem is that the area to the back of the camera is very dark. I've attached the scene I'm trying to render and as you can see the area to the back of the ship (should be a door) is extremely dark and shadowy as is the sky (would appear as not having any stars)
I've seen someone with this same mental ray + wraparound setup on YouTube and they are not having this issue
Same thing happens when I use the panorama exporter.
Note: You can see the issue in the attachment alone but I recommend opening in a 360/panorama viewer
