3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Multiplying 3 maps query
3 REPLIES 3
thor98_
398 Views, 3 Replies
It's my first day trying out the slate material editor. I need to multiply 3 vertex color channels on top of my diffuse map.
To my surprise the result looks correct, but the node setup looks really odd.
My question is if there's anything I can change to keep it more simple. Perhaps I can somehow add an additional input to the multiply map?
Thor Nielsen
3D Generalist
3 REPLIES 3
oliver
in reply to: thor98_
Try Layer RGBA.
thor98_
in reply to: oliver
Thank you. I'm very sure this is exactly what I need.
I'll reply back if I get stuck!
Thor Nielsen
3D Generalist
madsd
If you want to multiply 3 points.
Here is a shader that does so.
You can also integrate the UV channel directly into this shader so that your UV maps and multiply maps gets sweeped up into 1 single map.
shader MultiMap
	point a = 0,
	point b = 0,
	point c = 0,
	output point Out = 0,
	Out = a*b*c;
