When I create a mesh light and add an object, it keeps its defoult color.
So, how do i make a neon effect?
I've seen that i have to mix a emissive shader and mesh light but i think that it isn't eficcient, the arnold guide said that in some case the mesh light is better because it has less noise in shadows
Solved by CiroCardoso3v. Go to Solution.
You need to assign a material to the mesh emitting the light
